I am using Pololu maestro servo controller 18 channel.
I wanted to know is a way to control 2 or more servos simultaneously i.e drag the buttons of 2 or more servos at a time to displace them with equal angles.
Thank you for your Maestro USB Servo Controller purchase. The Maestro Control Center does not have an option to control two channels together from one slider. Two servos can move at the same time, but you would have to do that using the sequencer or by writing a script.
Alternatively, you might be able to connect the signal wires from both servos to the same channel with a Servo Y-Cable.
-Derrill
