I’m trying to hook up my Zumo to a receiver so that I can control it with a Flysky transmitter so I can drive it like a tank. However, I haven’t been able to find any information on how to do so. Has anyone accomplished this, and if so, how did you do it? Thanks in advance.
Could you clarify which version of the Zumo robot you are using? Are you using a Zumo Robot for Arduino, an original Zumo 32U4 Robot, or a Zumo 32U4 OLED Robot?
Brandon,
Thanks for the quick response. I’m using an original Zumo 32U4 Robot, but I happen to figure things out through trial and error. Basically, I plugged the wire for the left and right side in almost every connection on the receiver until I got results then started adjusting in my controller, and if that didn’t work, I moved to the next receiver connection. Not the most scientific way to get things done, but my Zumo work
Again, thanks for the quick response and have a great week.
Tommy
