I have installed the full suite for Pololu maestro 18 card, and successfully used the pololu maestro control center to test a standard and a continuous servos.
I’m now trying to use vb.net to use them, thanks to the provided exemple.
I does not work at all, as the Device list returned by GetConnectedDevices is empty.
I’m on W7 home edition, with a totally standard configuration.
What am i doing wrong?
Thanks in advance…
Ranngalon
Hello, Ranngalon.
I am sorry you are having trouble with the Maestro. What version of the Pololu USB SDK did you download? What is the name of the example code you are running? Are you able to connect to the Maestro from the Maestro Control Center?
The last version of the sdk, downloaded from your site (July 2012).
The example is SmcExample1Vb.
From the Maestro Control Center, everything works fine, so it’s why i think i’m doing something bad…
Ranngalon
SMC stands for Simple Motor Controller. Please try the examples with “Maestro” in the name.
Well, i feel a little bit stupid this time…
works fine now…
Thanks!
