Using a Pololu 4054 proximity switch. How to connect to computer through USB?
The output is a single 5V signal.
I moved your post to a more appropriate section of the forum.
The #4054 Digital Distance Sensor does not have a USB interface. You would need a separate device that can read a digital signal and has a USB interface. For example, you could probably program an Arduino or one of our Arduino-compatible A-Star controllers to do something like that.
If you can post more details about what you are trying to do, I might have some additional suggestions.
