I am not familiar with the AVR Wifi library in which you are referring to. Could you please provide a link to its documentation so I can see if it can work with the Baby Orangutan and the Arduino Wifi shield?
That Arduino Wifi shield uses SPI to communicate with an Arduino. Unfortunately, the MOSI line (used in SPI communication) is not accessible easily on the Baby Orangutan. You can access it through one of the ICSP programming pins; however, that might get in the way of programming the Baby Orangutan. You might consider loading the Arduino bootloader onto the Baby Orangutan so you could program it through a serial connection. Please note, the clock frequency on the Baby Orangutan is 20 MHz (Arduino runs at 16MHz) and might require some modification to the bootloader. You might find this thread discussing using the Arduino bootloader at 20 MHz helpful.
Hi Jeremy,
Thank you for your response. We have found all the information and documents through the internet, but cannot find the AVR compatible WiFi Library. So, we wonder that can we rewrite the Arduino WiFi Library into Baby Orangutan compatible library and program it with Arduino environment like the method in https://www.pololu.com/docs/0J17/5.
The other question is that there are 6 ISP pins on Baby Orangutan so can we just choose one of the six pins randomly as MOSI line?
Thank you again for your helpful replies.
The Arduino UNO uses an AVR ATmega328P, so the WiFi library you found is AVR-compatible. The Baby Orangutan uses the same AVR, so you probably will be able to modify it and use it similarly to what is described in the section of the guide you linked to.
You cannot randomly select one of the six pins; the MOSI line is pin 4 on the ISP connector.
Thank you Jeremy,
You really give us some helpful informations and encourage us to continue our project. If we run into difficulties when conductiing our project, we will try our best to find the answers and hope you can still give us some suggestions.
Thanks again!
