I am new to the screen. I am trying to use two digital distance sensor with two servo, a pot, and maestro 12-channel servo controller.
1.I need each sensor to trigger the same servo#1 at the low output separetely and when both sensor are outputing low voltage at the same time trigger the other servo#2.
2.Also, I need a switch that triggers servo#1 and a pot that controls the position of servo#1.
There are a few example scripts in the Maestro User’s Guide, such as using a potentiometer to control the position of a servo and using buttons to control a servo, that you might find useful. You might try using those example scripts as the starting point and modifying them for your project. If you run into any issues, you could post your script and I can take a look at it.
- Jeremy
