I’m very new with qtr array sensors. But I cant compile this code to test the sensor
I get the following error message in the line ’ QTRsensors qtr;’ – " Compilation error: ‘QTRSensors::QTRSensors()’ is protected within this context"
Whats wrong here guys
The full error message :
C:\Users\LENOVO\AppData\Local\Temp.arduinoIDE-unsaved20221124-4784-1nbmxlg.a088\sketch_dec24c\sketch_dec24c.ino:16:12: error: ‘QTRSensors::QTRSensors()’ is protected within this context
QTRSensors qtr;
In file included from C:\Users\LENOVO\AppData\Local\Temp.arduinoIDE-unsaved20221124-4784-1nbmxlg.a088\sketch_dec24c\sketch_dec24c.ino:1:0:
C:\Users\LENOVO\OneDrive\Documents\Arduino\libraries\QTRSensors/QTRSensors.h:133:5: note: declared protected here
QTRSensors()
C:\Users\LENOVO\AppData\Local\Temp.arduinoIDE-unsaved20221124-4784-1nbmxlg.a088\sketch_dec24c\sketch_dec24c.ino:16:12: error: cannot declare variable ‘qtr’ to be of abstract type ‘QTRSensors’
QTRSensors qtr;
C:\Users\LENOVO\OneDrive\Documents\Arduino\libraries\QTRSensors/QTRSensors.h:48:7: note: because the following virtual functions are pure within ‘QTRSensors’:
class QTRSensors
C:\Users\LENOVO\OneDrive\Documents\Arduino\libraries\QTRSensors/QTRSensors.h:148:18: note: virtual void QTRSensors::readPrivate(unsigned int*)
virtual void readPrivate(unsigned int *sensor_values) = 0;
C:\Users\LENOVO\AppData\Local\Temp.arduinoIDE-unsaved20221124-4784-1nbmxlg.a088\sketch_dec24c\sketch_dec24c.ino: In function ‘void setup()’:
C:\Users\LENOVO\AppData\Local\Temp.arduinoIDE-unsaved20221124-4784-1nbmxlg.a088\sketch_dec24c\sketch_dec24c.ino:24:7: error: ‘class QTRSensors’ has no member named ‘setTypeRC’
qtr.setTypeRC();
C:\Users\LENOVO\AppData\Local\Temp.arduinoIDE-unsaved20221124-4784-1nbmxlg.a088\sketch_dec24c\sketch_dec24c.ino:25:7: error: ‘class QTRSensors’ has no member named ‘setSensorPins’; did you mean ‘QTRSensors’?
qtr.setSensorPins((const uint8_t){3, 4, 5, 6, 7, 8, 9, 10}, SensorCount);
QTRSensors
C:\Users\LENOVO\AppData\Local\Temp.arduinoIDE-unsaved20221124-4784-1nbmxlg.a088\sketch_dec24c\sketch_dec24c.ino:26:7: error: ‘class QTRSensors’ has no member named ‘setEmitterPin’; did you mean ‘_emitterPin’?
qtr.setEmitterPin(2);
_emitterPin
Multiple libraries were found for “QTRSensors.h”
Used: C:\Users\LENOVO\OneDrive\Documents\Arduino\libraries\QTRSensors
Not used: C:\Users\LENOVO\OneDrive\Documents\Arduino\libraries\qtr-sensors-arduino-master
exit status 1
