i’m a college student from malaysia,i’m trying to fix the sample project (project 1) as posted,i got the pololu motor controller but i can’t find the tamiya motor in the market,so wat should i replace it?/help me plz…
You should be able to use any chassis that uses small DC motors. You can take a look at project 2, which is very similar to sample project 1, but uses LEGO motors instead. There are many small gearboxes or gearmotors out there that you can use, and as long as the current and voltage requirements are within the motor controller specs, you just need to find something that works for you.
- Jan
hi,sir
if i want to use the same project with attching the mini vacuum cleaner,can it work??make it look like automated PIC vacuum clea 8) ner.
Sure, you could put a (really) small vacuum cleaner on the chassis, but I don’t think you would get much useful vacuuming out of it!
- Jan
ok,thanks for your answer,i’ll try to fix it.
i can’t find the Tamiya 70097 Twin-Motor in my country,what other motor u suggest me to replace??
