Hi, I want to drive two micro servos DMS44 with the Micro Maestro 6 to rotate a plastic bar around the Z and X axis at the same time. One servo will be mounted onto the plate and the rotor will be free to rotate on the horizontal surface. The second servo will be jointed to the first servo and its rotor will be rotating on the vertical surface.
I have one pololu plate, the two servos DMS44, their horns and screws.
The question is what other material (screws, standoffs,etc…) do I need to:
- fix the first motor to the pololu plate
- joint the second servos to the first servos in a “clean way”. E.g. should I use the horns?
Links to the right material would be much appreciated.
