Dear,
When I use the “Continious”-example sketch of the vl5310x library I receive only 65535 TIMEOUT readings. When I use the “Single”-example sketch I receive a 0 or a 65535 TIMEOUT reading.
Do you have any idea what is going on?
Kind regards, Michel.
Hello, Michel.
We wrote that library specifically to work with our VL53L0X carrier board. If you are having trouble using it with a different product, you should contact the manufacturer of that product for technical support or for recommended software that works with their device.
-Nathan
