Hello, i got a problem, i lost my 4 pin connector wire of my chr um6 ımu sensor.
I need a connector or another solution for keeping my sensor stable please help, need to solve that stability problem.
Unfortunately, we do not have replacement cables for that sensor. However, according to the UM6 datasheet (page 10), part number A98655-ND from Digi-Key is a compatible connector for the 4-pin side output, so you can use that to try to find a suitable replacement.
You could also try contacting Redshift Labs to see if they might have replacement cables.
- Patrick
