I’m using the 37D gearmotor brackets to mount 4 19:1 motors to my robot chassis. I want to mount it so only the motor shaft sticks out the side of the chassis, so the bracket needs to mount close to the side, but not flush. I’d like to mount the motor to the bracket and then mount the motor to the chassis, but with a motor installed, it’s going to be extremely hard to get a screwdriver on a screw that would go through chassis bottom into the holes in the bracket. If I try to mount the bracket first, I won’t be able to get to the screws on the end to screw in the motor.
I’ve been scratching my head about this and I’m sure someone else has faced a similar problem. Does anyone have a suggestion?
Mark
