I want to know more about how to charge this battery pack:
https://www.pololu.com/catalog/product/2231
It has a 2-pin connector (JR) that is not easy to find in the average battery chargers I can find for hobby electronics. Also the 900mAh is lower than the stated use for most of the chargers I can find. Typically a minimum is around 1300mAh.
I gather that a slow (10-14 hr) charge should be at about 90mA for this pack, yet most chargers seem to be set at either 900mA or 1.8A.
Does anyone have this battery pack? What do you use to charge it?
I’ve found these that I think might work. Opinions?
http://www.all-battery.com/smartuniversalchargerfornimhbatterypack24v-72v.aspx
http://www.zbattery.com/Smart-Charger-for-4-8V-10-8V-NiMH-NiCd-Battery-Packs
They seem nearly identical… And neither matches this battery pack spec.
