Hey everyone,
I’m working on a small motor driver module. It needs to be easily soldered onto a main PCB. I am trying to follow how Pololu’s motor driver and sensor breakout boards use castellated holes for edge mounting. While researching, I found this article: Understanding Castellated Holes in PCB Manufacturing. It explains the manufacturing process and common use cases.
I’m considering using castellated holes, but I have a few concerns:
- Do castellated connections hold up well under repeated soldering and desoldering, or do they wear out quickly?
- Is there a minimum recommended pad size for castellated edges to ensure reliable solder joints?
- Would adding plated edge vias improve mechanical strength, or would they just complicate manufacturing?
If anyone has experience designing castellated PCBs for compact modules, I’d love to hear your insights!
