Hi I´m new here, which sensor is the most adequate to capture information about location (latitud and longitud) and time between locations. Once you get the information how can you download that information.
GPS receivers like this one are probably the most appropriate devices to use to get time and location information like that. That particular module has a 3.3V TTL serial interface, so to get information from it, you could use a USB-to-serial adapter like this one or a separate microcontroller that works with a 3.3V TTL serial interface.
