Hi. I’ve installed the MaestroControlCenter app on a raspberry pi running Raspbian but when I attempt to start it (via VNC) I get the following:
pi@raspberrypi ~/maestro_linux $ ./MaestroControlCenter
Unhandled Exception: System.TypeInitializationException: An exception was thrown by the type initializer for System.Windows.Forms.XplatUI ---> System.Net.Sockets.SocketException: The requested address is not valid in this context
at System.Net.Sockets.Socket.Bind (System.Net.EndPoint local_end) [0x00000] in <filename unknown>:0
at System.Windows.Forms.XplatUIX11.SetDisplay (IntPtr display_handle) [0x00000] in <filename unknown>:0
at System.Windows.Forms.XplatUIX11..ctor () [0x00000] in <filename unknown>:0
at System.Windows.Forms.XplatUIX11.GetInstance () [0x00000] in <filename unknown>:0
at System.Windows.Forms.XplatUI..cctor () [0x00000] in <filename unknown>:0
--- End of inner exception stack trace ---
at System.Windows.Forms.Application.EnableVisualStyles () [0x00000] in <filename unknown>:0
at Pololu.MaestroControlCenter.Program.Main () [0x00000] in <filename unknown>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: An exception was thrown by the type initializer for System.Windows.Forms.XplatUI ---> System.Net.Sockets.SocketException: The requested address is not valid in this context
I can run ./UscCmd ok from the shell. Will MaestroControlCenter work over VNC?
Thanks
