I recently received an orangutan svp 1284 and have read the documentation to make sure I didn’t miss something obvious, because this feels like a question with a very simple answer.
The default program worked out of the box (and I do have version 1.03), but I haven’t been able to load any firmware to it. I am using examples from the libpololu-avr library, libpololu-avr/examples/atmega1284p/simple-test, in Linux.
As described in the documentation, I made the hex files and tried to run make program to upload the new program, but the outputs I am getting from avrdude are :
avrdude: Device signature = 0x1e9705
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: stk500v2_command(): warning: Command timed out
avrdude: stk500v2_command(): command failed
One time, randomly, it looked like it was working, but ended up just wiping the default program instead, now i get a blank lcd and still cannot upload the new program. Is there something obvious I am missing like a jumper position or a programming mode setting? Thanks
