When I try running the executable file, which I have extracted to my desktop, I get an error.
"An error occurred whiled downloading a required file. You may retry downloading the file or cancel setup.
Also, if it helps, my computer is not connected to the internet. Might that hold things up?
I also asked chatGPT (haha) and it recommended me to download .NET Framework 3.5, but I couldn’t get that to work either
Below is my error log:
The following properties have been set: Property: [AdminUser] = true {boolean} Property: [ProcessorArchitecture] = AMD64 {string} Property: [VersionNT] = 6.2.0 {version} Running checks for package 'Windows Installer 3.1', phase BuildList The following properties have been set for package 'Windows Installer 3.1': Running checks for command 'WindowsInstaller3_1\WindowsInstaller-KB893803-v2-x86.exe' Result of running operator 'VersionGreaterThanOrEqualTo' on property 'VersionMsi' and value '3.1': true Result of checks for command 'WindowsInstaller3_1\WindowsInstaller-KB893803-v2-x86.exe' is 'Bypass' 'Windows Installer 3.1' RunCheck result: No Install Needed Running checks for package '.NET Framework 3.5', phase BuildList Reading value 'Install' of registry key 'HKLM\Software\Microsoft\NET Framework Setup\NDP\v3.5\1033' Unable to read registry value Not setting value for property 'DotNet35InstallSuccess' The following properties have been set for package '.NET Framework 3.5': Running checks for command 'DotNetFX35\dotNetFx35setup.exe' Skipping ByPassIf because Property 'DotNet35InstallSuccess' was not defined Result of running operator 'ValueEqualTo' on property 'AdminUser' and value 'false': false Result of running operator 'ValueExists' on property 'Version9x': false Result of running operator 'VersionLessThan' on property 'VersionNT' and value '5.1.2': false Result of running operator 'VersionEqualTo' on property 'VersionNT' and value '5.2.0': false Result of running operator 'ValueEqualTo' on property 'ProcessorArchitecture' and value 'IA64': false Result of checks for command 'DotNetFX35\dotNetFx35setup.exe' is 'Install' '.NET Framework 3.5' RunCheck result: Install Needed EULA for components '.NET Framework 3.5' was accepted. Copying files to temporary directory "C:\Users\dcapo\AppData\Local\Temp\VSD95DD.tmp\" Downloading files to "C:\Users\dcapo\AppData\Local\Temp\VSD95DD.tmp\" (4/22/2024 2:18:08 AM) Downloading 'DotNetFX35\dotNetFx35setup.exe' from 'http://go.microsoft.com/fwlink/?LinkId=97964' to 'C:\Users\dcapo\AppData\Local\Temp\VSD95DD.tmp\' Download completed at 4/22/2024 2:18:08 AM Downloading failed with HRESULT=-2146697211 (4/22/2024 2:18:12 AM) Downloading 'DotNetFX35\dotNetFx35setup.exe' from 'http://go.microsoft.com/fwlink/?LinkId=97964' to 'C:\Users\dcapo\AppData\Local\Temp\VSD95DD.tmp\' Download completed at 4/22/2024 2:18:12 AM Downloading failed with HRESULT=-2146697211 (4/22/2024 2:19:55 AM) Downloading 'DotNetFX35\dotNetFx35setup.exe' from 'http://go.microsoft.com/fwlink/?LinkId=97964' to 'C:\Users\dcapo\AppData\Local\Temp\VSD95DD.tmp\' Download completed at 4/22/2024 2:19:56 AM Downloading failed with HRESULT=-2146697211 (4/22/2024 2:19:56 AM) Downloading 'DotNetFX35\dotNetFx35setup.exe' from 'http://go.microsoft.com/fwlink/?LinkId=97964' to 'C:\Users\dcapo\AppData\Local\Temp\VSD95DD.tmp\' Download completed at 4/22/2024 2:19:56 AM Downloading failed with HRESULT=-2146697211
