Hi, I have a 10 sensors array, it is based on Qtr-8A. Can i use the corresponding library to read the line position ???
The read line command works on arbitrary lengths of QTR arrays, so you should be able to use the read line command to get the position of the line relative to your 10 sensor array.
If you run into issues, you can post your code and pictures of your setup, and I would be happy to take a look.
- Jeremy
