I am working on a game with the QTR 8A but in order to calibrate the sensor correctly, the robot needs to move about 7 to 9 times back and forth. I made it in an while loop but the while loop doesn’t run.
here is my current code
#include <QTRSensors.h>
//wheels
int reverseRight = 9;
int forwardRight = 10;
int reverseLeft = 6;
int forwardLeft = 11;
//pulsesensor
int speedSensorA = 2;
int speedSensorB = 3;
int counterA = 0;
int counterB = 0;
//line tracker
QTRSensors qtr;
const int SensorCount = 6;
int sensorValues[SensorCount];
void setup(){
Serial.begin(9600);
pinMode(forwardLeft, OUTPUT);
pinMode(forwardRight, OUTPUT);
pinMode(reverseLeft, OUTPUT);
pinMode(reverseRight, OUTPUT);
pinMode(speedSensorA, INPUT_PULLUP);
pinMode(speedSensorB, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(speedSensorA), countA, CHANGE);
attachInterrupt(digitalPinToInterrupt(speedSensorB), countB, CHANGE);
qtr.setTypeAnalog();
qtr.setSensorPins((const byte[]){A0, A1, A2, A3, A4, A5}, SensorCount);
while(calibratie(360)){ //this while loop doesn't run
moveForward(25);
delayMicroseconds(80);
moveBackward(25);
moveForward(25);
//this runs normally
// moveForward(25);
// delayMicroseconds(80);
// moveBackward(25);
//delayMicroseconds(80);
// moveForward(25);
void loop(){
bool calibratie(int timesLoop){
for (int i = 0; i < timesLoop; i++)
qtr.calibrate();
digitalWrite(LED_BUILTIN, LOW); // turn off Arduino's LED to indicate we are through with calibration
// print the calibration minimum values measured when emitters were on
for (int i = 0; i < SensorCount; i++)
Serial.print(qtr.calibrationOn.minimum[i]);
Serial.print(' ');
Serial.println();
// print the calibration maximum values measured when emitters were on
Serial.print(qtr.calibrationOn.maximum[i]);
Serial.print(' ');
Serial.println();
Serial.println();
void stopVehicle(){
analogWrite(forwardLeft, LOW);
analogWrite(forwardRight, LOW);
analogWrite(reverseLeft, LOW);
analogWrite(reverseRight, LOW);
counterA = 0;
counterB = 0;
void moveForward(int pulsecount) {
while(counterA <= pulsecount){
analogWrite(forwardLeft, 200);
analogWrite(forwardRight, 210);
stopVehicle();
counterA = 0;
counterB = 0;
void moveBackward(int pulsecount) {
analogWrite(reverseLeft, 200);
analogWrite(reverseRight, 210);
stopVehicle();
counterA = 0;
counterB = 0;
void countA(){
counterA++;
void countB(){
counterB++;
