I am trying to extract heading value from the LSM303DLHC; I am using little endian microcontroller and referring to your posted code for guidance. I set the LSM303DLHC as follows:
Reg: 0x20, Val: 0x37
Reg: 0x23, Val: 0x88
Reg: 0x00, Val: 0x14,
Reg: 0x01, Val: 0xA0
Reg: 0x02, Val: 0x00
When I perform stationary position measurements, I get these values:
Raw data
Zb down ->
Ax: -22, Ay:-3, Az:1075, Mx: -26, My:-46 , Mz: -167
Zb up ->
Ax: -40, Ay:9, Az:-1027, Mx:-15 My: 29, Mz: 128
Yb down ->
Ax: -27, Ay: 1041, Az: -2, Mx: -14 My:-167, Mz: -14
Yb up->
Ax: -38, Ay: -1011, Az: -5, Mx: -15 My:145, Mz: -50
Xb down ->
Ax: -1079, Ay:37, Az: 40, Mx: 130 My: 13, Mz: 44
Xb up ->
Ax: 1028, Ay:10, Az: 13, Mx: -138 My: - 34, Mz: 45
I wanted to ask you about you calibration values for m vector that you came up with:
m_max.x = +540; m_max.y = +500; m_max.z = 180;
m_min.x = -520; m_min.y = -570; m_min.z = -770;
Did it come from your stationary position measurements?
I also noticed that you do not calibrate your accel data.
Thanks
Monika
