A student recently asked me for help on writing the C code to fill and edit the “turns” array for a line maze robot. Here is my reply which may help some…
So, your code will look something like…
int main(void)
char turns[50]; // Use a number here that is bigger than the number of turns you expect in the maze
char turn = 'U' /* This would be for a U-Turn. I use these characters for the turns:
'L' = Left
'R' = Right
'S' = Straight
'U' = U-Turn
The array starts out with nothing */
int pointer = 0; //Points to the next available position in the array.
//Now, each time you take a turn, add it to the list, like...
// (Say you took a left turn, so turn = 'L')
turns[pointer] = turn; //This puts an L in the first position of the array
pointer++ //Add one to the pointer so the next letter goes in the next position in the array.
// and later you take a left, then a U-Turn, then come back to the intersection and take a left. The array now looks like:
// turns = 'LLUL'
// showing that the first four turns were left, left, u-turn, then a left.
//EVERY time you take a turn, go to a function called 'check' to see if the next-to-last character in the array is a 'U'.
//If the next-to-last character is a 'U', then the last turn was unnecessary.
//check() will look something like:
void check(turns, int pointer)
if (len(turns) < 3) //Need at least three characters for this algorithm to work
return;
if (turns[pointer] - 1 != 'U') // Exit if the next-to-last turn is NOT a U-Turn
return;
//Then pick out the possibilities and replace the last three characters with the turn the robot SHOULD HAVE TAKEN INSTEAD.
//I'll do 2, you do the others...
if (right.turns[3] == 'LUL') //Look at the right three characters in the array
pointer = pointer - 3; //shorten the array by 3 characters. We'll "chop off" the LUL and replace with S
turns[pointer] = 'S'; //The turn we should have taken (and will take next time.
pointer++; // set up the pointer to point to the next character in the array.
if (right.turns[3] == 'RUR') //Look at the right three characters in the array
pointer = pointer - 3; //shorten the array by 3 characters. We'll "chop off" the RUR and replace with S
//...and so on for the combinations you have in your maze.
