I have a application using a D36V50Fx Regulator providing 9v to a inductive load, (sprinkler valve solenoid), as part of my startup sequence I want to bypass the D36V50Fx with 13v to help boost the solenoid to pull in, then later drop it to 9v to hold… is there a problem with me feeding 13v back through the output pin. or do I need to add an additional diode to the circuit to protect the regulator?
In this diagram the 9v is provided by the D36V50Fx
thank you.
