I’m just starting out with the maestro servo controllers and have a button issue. I can start a sequence on button push but how do suspend the script or stop it then start again on button up.
If I put wait_for_button_open_10ms as the first line under Begin this works but only after the script get back to the beginning so there is a delay suspending the script.
Where is the code tag option?
Code follows, no it doesn’t work
indent preformatted text by 4 spaces
# stab
goto main_loop # Run the main loop when the script starts (see below).
# This subroutine returns 1 if the button is pressed, 0 otherwise.
# To convert the input value (0-1023) to a digital value (0 or 1) representing
# the state of the button, we make a comparison to an arbitrary threshold (500).
# This subroutine puts a logical value of 1 or a 0 on the stack, depending
# on whether the button is pressed or not.
sub button
0x10 get_position 500 less_than
return
# This subroutine uses the BUTTON subroutine above to wait for a button press,
# including a small delay to eliminate noise or bounces on the input.
sub wait_for_button_press
wait_for_button_closed_10ms
return
# Wait for the button to be NOT pressed for at least 10 ms.
sub wait_for_button_open_10ms
get_ms # put the current time on the stack
begin
# reset the time on the stack if it is pressed
button
if
drop get_ms
else
if drop return endif
endif
repeat
# Wait for the button to be pressed for at least 10 ms.
sub wait_for_button_closed_10ms
get_ms
begin
# reset the time on the stack if it is not pressed
button
if
else
drop get_ms
endif
repeat
#main_Loop#
sub Stab_0
begin
500 3968 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 frame_0..15_17 # head R
500 7882 frame_0 # head L
500 6000 frame_0 # head Nuteral
500 0 4144 frame_0_1 # R shd Babk
500 6943 frame_1 # R shd Fwd
500 5984 frame_1 # R shd nuteral
500 0 8000 frame_1_2 # L shd Back
500 4065 frame_2 # L shd fwd
500 6003 frame_2 # L shd nuteral
500 0 4046 frame_2_3 # R shd up
500 0 8000 frame_3_5 # st stab
200 4046 frame_5 # sd1
200 7628 frame_5 # su1
200 4202 frame_5 # sd2
200 7725 frame_5 # su2
200 4202 frame_5 # su3
300 5964 frame_5 # stp stab
500 0 7745 frame_5_10 # l hip back
500 4202 frame_10 # l hip fwd
500 6003 frame_10 # l hip nuteral
500 0 frame_10 # all off
repeat
main_loop:
sub Frame
# wait_for_button_closed_10ms
wait_for_button_open_10ms # shouldn't this stop the script,stay in button loop while button is closed?
# wait_for_button_press # i guess hte question is how to exit begin-repeat then resume where I left off
stab_0
sub frame_0..15_17
17 servo
15 servo
14 servo
13 servo
12 servo
11 servo
10 servo
9 servo
8 servo
7 servo
6 servo
5 servo
4 servo
3 servo
2 servo
1 servo
0 servo
delay
return
sub frame_0
0 servo
delay
return
sub frame_0_1
1 servo
0 servo
delay
return
sub frame_1
1 servo
delay
return
sub frame_1_2
2 servo
1 servo
delay
return
sub frame_2
2 servo
delay
return
sub frame_2_3
3 servo
2 servo
delay
return
sub frame_3_5
5 servo
3 servo
delay
return
sub frame_5
5 servo
delay
return
sub frame_5_10
10 servo
5 servo
delay
return
sub frame_10
10 servo
delay
return
