I converted an AVR Studio 4 Orangutan SV-328 project using Atmel Studio 6.2. The project builds fine in AVR4 but when I build the converted project in 6.2, I get the following output:
------ Rebuild All started: Project: centeron, Configuration: default AVR ------
Build started.
Project "centeron.cproj" (Clean target(s)):
Target "Clean" in file "C:\Program Files\Atmel\Atmel Studio 6.2\Vs\Compiler.targets" from project "C:\Users\username\Documents\Company\Projects-products\Project\atmel 6\centeron-sv328_V5.0\centeron.cproj" (entry point):
Using "RunCompilerTask" task from assembly "C:\Program Files\Atmel\Atmel Studio 6.2\Extensions\Application\AvrGCC.dll".
Task "RunCompilerTask"
Shell Utils Path C:\Program Files\Atmel\Atmel Studio 6.2\shellUtils
C:\Program Files\Atmel\Atmel Studio 6.2\shellUtils\make.exe clean
rm -rf centeron.o menu.o global.o utils.o serial.o
rm -rf centeron.d menu.d global.d utils.d serial.d
rm -rf "centeron.elf" "centeron.a" "centeron.hex" "centeron.lss" "centeron.eep" "centeron.map" "centeron.srec" "centeron.usersignatures"
Done executing task "RunCompilerTask".
Done building target "Clean" in project "centeron.cproj".
Done building project "centeron.cproj".
Build succeeded.
Build started.
Project "centeron.cproj" (default targets):
Target "PreBuildEvent" skipped, due to false condition; ('$(PreBuildEvent)'!='') was evaluated as (''!='').
Target "CoreBuild" in file "C:\Program Files\Atmel\Atmel Studio 6.2\Vs\Compiler.targets" from project "C:\Users\username\Documents\company\Projects-products\Project\atmel 6\centeron-sv328_V5.0\centeron.cproj" (target "Build" depends on it):
C:\Program Files\Atmel\Atmel Studio 6.2\shellUtils\make.exe all
The system cannot find the path specified.
make: *** [centeron.o] Error 1
Building file: .././centeron.c
Invoking: AVR/GNU C Compiler : 0.0.0
"C:\Program Files\WinAVR-20100110\bin\avr-gcc.exe" -x c -funsigned-char -funsigned-bitfields -Os -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -Wall -mmcu=atmega328p -c -gdwarf-2 -std=gnu99 -MD -MP -MF "centeron.d" -MT"centeron.d" -MT"centeron.o" -o "centeron.o" ".././centeron.c"
Done executing task "RunCompilerTask" -- FAILED.
Done building target "CoreBuild" in project "centeron.cproj" -- FAILED.
Done building project "centeron.cproj" -- FAILED.
Build FAILED.
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
The error message says: “The system cannot find the path specified” but it is not clear to me which path it cannot find.
Any ideas?
Thanks,
Burke
