RomiRPiSlaveDemo
I can not do it
wget https://github.com/pololu/pololu-rpi-slave-arduino-library/archive/<version>.tar.gz tar -xzf <version>.tar.gz
Executing the above will result in an error
Tell me the solution
RomiRPiSlaveDemo
I can not do it
I moved your post to our Robots sub-forum, which seemed more appropriate.
Did you replace <version>
in that command with the version of the library that you installed for the Arduino IDE (e.g. “2.0.0”) as stated in the “Part 5: Testing the I2C bridge” section of the Building a Raspberry Pi robot with the A-Star 32U4 Robot Controller" tutorial? If replacing <version>
with the Raspberry Pi slave library’s version number does not fix the problem, can you post the error message you are seeing?
- Amanda
