Hello to everyone. I encountered some problems in buffering data for usb serial transmission, and I would like to know if it is problem that is related to variable dimensioning or… what else?
I give you a little example. In the code you’ll find below, I am trying to implement a small circular buffer. (My long-term goal will be to use it for sampling a signal and later encode it and transmit it). As you can see, MAX_ITEMS is defined as 10. If I try to define a bigger value, or even if I try to uncomment the printf instructions in the main loop, transmission crashes after few loops. I would like to know if it is a problem related to USB buffering or other things that I, like a newbie, cannot understand.
Thanks a lot,
Tapisge
/** Ste_queue_test app:
* Simple test for a circular queue.
#include <wixel.h>
#include <usb.h>
#include <usb_com.h>
#include <stdio.h>
#define MAX_ITEMS 10
typedef struct circularQueue_s
int first;
int last;
int validItems;
int element[MAX_ITEMS];
} circularQueue_t;
circularQueue_t XDATA myQueue;
// A big buffer for holding a report. This allows us to print more than
// 128 bytes at a time to USB.
uint8 XDATA report[1024];
// The length (in bytes) of the report currently in the report buffer.
// If zero, then there is no report in the buffer.
uint16 DATA reportLength = 0;
// The number of bytes of the current report that have already been
// send to the computer over USB.
uint16 DATA reportBytesSent = 0;
void initializeQueue(circularQueue_t *theQueue){
int i;
theQueue->validItems = 0;
theQueue->first = 0;
theQueue->last = 0;
for(i=0; i<MAX_ITEMS; i++)
theQueue->element[i] = 0;
BIT isEmpty(circularQueue_t *theQueue){
if(theQueue->validItems==0)
return(1);
else
return(0);
BIT putItem(circularQueue_t *theQueue, int theItemValue){
if(theQueue->validItems>=MAX_ITEMS){
return(0);
else{
theQueue->validItems++;
theQueue->element[theQueue->last] = theItemValue;
theQueue->last = (theQueue->last+1)%MAX_ITEMS;
return(1);
BIT getItem(circularQueue_t *theQueue, int *theItemValue){
if(isEmpty(theQueue)){
return(0);
else{
*theItemValue=theQueue->element[theQueue->first];
theQueue->first=(theQueue->first+1)%MAX_ITEMS;
theQueue->validItems--;
return(1);
void printQueue(circularQueue_t *theQueue){
int aux, aux1;
aux = theQueue->first;
aux1 = theQueue->validItems;
printf("QUEUE: ");
while(aux1>0)
printf("%3d", theQueue->element[aux]);
aux=(aux+1)%MAX_ITEMS;
aux1--;
printf("\r\n");
void updateLeds()
usbShowStatusWithGreenLed();
// This gets called by puts, printf, and printBar to populate
// the report buffer. The result is sent to USB later.
void putchar(char c)
report[reportLength] = c;
reportLength++;
void main()
static uint32 lastEvent;
uint8 bytesToSend;
int i, readValue;
systemInit();
usbInit();
lastEvent = 0;
LED_RED(1);
LED_YELLOW(0);
while(1)
boardService();
updateLeds();
usbComService();
if (getMs() - lastEvent >= 1000){
lastEvent=getMs();
//queue init
initializeQueue(&myQueue);
//printf("\x1B[0;0H");
//printf("Time: %6lu\r\n", lastEvent);
for(i=0; i<MAX_ITEMS+1; i++){
putItem(&myQueue, i);
printQueue(&myQueue);
for(i=0; i<MAX_ITEMS/2; i++){
getItem(&myQueue, &readValue);
printf("last = %2d\r\n", readValue);
printf("\r\n");
// Create reports.
// Send the report to USB in chunks.
if (reportLength > 0) {
bytesToSend = usbComTxAvailable();
if (bytesToSend > reportLength - reportBytesSent){
// Send the last part of the report.
usbComTxSend(report+reportBytesSent, reportLength - reportBytesSent);
reportLength = 0;
else{
usbComTxSend(report+reportBytesSent, bytesToSend);
reportBytesSent += bytesToSend;
LED_RED(!LED_RED_STATE);
