Hi Folks,
Anybody out there using a RAPU with a Maestro? Tips on settings? I have playback of a test routine (simple single servo motion) that is smooth when driving the Maestro from a laptop (using USB and setting the Maestro to USB Dual Port). I change the Maestro to UART 9600, plug her into the TTL out on the RAPU, and the same routine is garbage jittery motion.
The yellow LED on the Maestro is flashing in time with the jittery servo motion, so rule the servo out as a candidate of this issue.
Odd thing: you have to have the Maestro set to 9600 baud rate or the first command sent from the RAPU throws up a nice bright red LED fail on the Maestro.
TIA!
