hi there, i have a baby orangutan atmega328p and usb isp programmer plololu 1300. i have followed the instruction on pololu site and done everything, but when i type make program on my terminal it show as follow
[code]avrdude -p m328p -c avrisp2 -P /dev/tty.usbmodem00056023 -U flash:w:test.hex
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude: stk500v2_command(): failed miserably to execute command 0x10
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500v2_command(): failed miserably to execute command 0x11
avrdude: stk500v2_disable(): failed to leave programming mode
avrdude done. Thank you.[/code]
please help. thanks
