I’ve removed the MOSFET of several Pololu beacons (to disable IR’s), during the removal procedure i cut off the pins of the MOSFET’s .
Now i want to enable the IRs again.
Somebody knows which MOSFET are and where can i buy it, at least something similar please?
You should look for logic-level, N-channel MOSFETs in SOT-23 packages; they should all have the same pinout. You should pick something that can do more than 1A continuous, which is not much for modern power MOSFETs.
