Hello All,
So I bought the pololu mini 12 servo conrtoller. I have set up pin 15 on my basic stamp 2sx to the rx on the controller to serout. Both grounds are common. I have servo 0 connected to a servo tester that can read transmitted pulse width.
Here is a part of the code
Test:
Serout 15, 110, [$80, $01, $04, 0, 13, 127]
pause 10000
Serout 15, 110, [$80, $01, $04, 0, 35, 127]
Pause 10000
Goto test
End
The servo controller’s red led binks (which i know is not supose to happen) and the yellow led goes every 10 secods as in the above code.
The servo tester reads in the high 4000 for a pulse. I know that is not right. If i change, lets say, 35 to 60 the pulse does not change on the tester.
Is there somthing i am doing wrong in hooking up the controller or in my code?
Please let me know if you need anymore info or have any suggestions for me.
Once i get the controller to pluse out properly from serial commands i plan to run brushless esc.
Thanks in advance
Andrew
