Hello folks,
I just finished assembling Balboa 32u4, using 75:1 motors (applied magnetic encoders) at gear ratio 163:1 with 80x10 wheels and added fall-protection arms.
So far tested examples work (Blink, Buzzer sound). However the Balboa won’t balance. Using the Balance-example sketch and setting gear ratio in “Balance.h”, Balboa is far from balancing.
To test the robot it is placed onto the ground with board facing upwards. After waiting a few seconds, when turning the robot, I just keeps on driving forward without bringing itself into stand up position.
The motor test-sketch worked fine before.
Does anyone have a clue how to solve this problem?
BTW, I´m using Arduino-IDE.
