i´ve bought a Maestro 6 Servo Conroller with a custom Firmware. Now i want to test the Standard Firmware but without loosing the custom one.
Is it possible to BackUp or extract the custom Firmware or directly copying it to another Controller ?
Thank You!
CreepNo1C
I moved your post to the “Servo controllers and servos” section of the forum since it seemed more appropriate.
There is no way to get the firmware from the board like you described. You might try contacting the vendor you got it from to see if they can help you with that in some way.
Another option might be to get a separate Micro Maestro with the standard firmware so you could compare them side-by-side.
