I am starting a project with the BabyO and admittedly have only used code sections of other programs.
I have the motor code working fine using the example from the resources tab, and have tried to incorporate code from the OrangutanProject1, but I am sure I am missing something obvious. Basically I want to read the output from a ProxDot IR detector which has a single high/low digital output easy to interface with most microcontrollers - Digital output goes “low” when an object is in range - These will be connected to PC0 and PC2
I tried to modify the code based on the commented sections in the OrangutanProject1, but I must have missed something obvious as I get no response from the motors. Here is what I have:
#include <avr/io.h>
// Motor Control Functions -- pwm is an 8-bit value
// (i.e. ranges from 0 to 255)
void M1_forward(unsigned char pwm)
OCR0A = 0;
OCR0B = pwm;
void M1_reverse(unsigned char pwm)
OCR0B = 0;
OCR0A = pwm;
void M2_forward(unsigned char pwm)
OCR2A = 0;
OCR2B = pwm;
void M2_reverse(unsigned char pwm)
OCR2B = 0;
OCR2A = pwm;
// Motor Initialization routine -- this function must be called
// before you use any of the above functions
void motors_init()
// configure for inverted PWM output on motor control pins:
// set OCxx on compare match, clear on timer overflow
// Timer0 and Timer2 count up from 0 to 255
TCCR0A = TCCR2A = 0xF3;
// use the system clock/8 (=2.5 MHz) as the timer clock
TCCR0B = TCCR2B = 0x02;
// initialize all PWMs to 0% duty cycle (braking)
OCR0A = OCR0B = OCR2A = OCR2B = 0;
// set PWM pins as digital outputs (the PWM signals will not
// appear on the lines if they are digital inputs)
DDRD |= (1 << PORTD3) | (1 << PORTD5) | (1 << PORTD6);
DDRB |= (1 << PORTB3);
#define F_CPU 8000000 // system clock is 20 MHz
#include <util/delay.h> // uses F_CPU to achieve us and ms delays
// delay for time_ms milliseconds by looping
// time_ms is a two-byte value that can range from 0 - 65535
// a value of 65535 (0xFF) produces an infinite delay
void delay_ms(unsigned int time_ms)
// _delay_ms() comes from <util/delay.h> and can only
// delay for a max of around 13 ms when the system
// clock is 20 MHz, so we define our own longer delay
// routine based on _delay_ms()
unsigned int i;
for (i = 0; i < time_ms; i++)
_delay_ms(1);
int main()
// Pin Assignments for ProxDots
DDRC &= ~(1 << PORTC2); // make pin PC2 an input
PORTC |= (1 << PORTC2); // enable pull-up on pin PC2 (this means pin PC2
// will read as high unless externally driven low)
while (1)
if (PINC & (1 << PORTC2)) // if pin PC2 input reads as high, RUN MOTORS
M1_forward(125);
M2_forward(125);
else // stop motors
M1_forward(0); // Stopped
M2_forward(0); // Stopped
} //close while
} //close main
I will be using PC0 AND PC2, but am just testing the functionality with PC2.
Any thoughts are appreciated.
Thanks,
Mike
