I am struggling getting the UART serial transmission going on my Baby-O, there is communication but the baudrate does not seem to match.
For testing I used the Pololu Library example, as I do not have any buttons I moved the “Hi there!” outside the push button action and created a 1 sec interval.
/* uart3 - an application for the Pololu Baby Orangutan B
* This application uses the Pololu AVR C/C++ Library. For help, see:
* -User's guide: https://www.pololu.com/docs/0J20
* -Command reference: https://www.pololu.com/docs/0J18
* Created: 5/11/2015 4:35:31 PM
* Author: Zolder
#include <pololu/orangutan.h>
* serial1: for the Orangutan controllers and 3pi robot.
* This example listens for bytes on PD0/RXD. Whenever it receives a byte, it
* performs a custom action. Whenever the user presses the middle button, it
* transmits a greeting on PD1/TXD.
* The Baby Orangutan does not have a green LED, LCD, or pushbuttons so
* that part of the code will not work.
* To make this example compile for the Orangutan SVP, you
* must add a first argument of UART0 to all the serial_*
* function calls.
* https://www.pololu.com/docs/0J20
* https://forum.pololu.com
// receive_buffer: A ring buffer that we will use to receive bytes on PD0/RXD.
// The OrangutanSerial library will put received bytes in to
// the buffer starting at the beginning (receiveBuffer[0]).
// After the buffer has been filled, the library will automatically
// start over at the beginning.
char receive_buffer[32];
// receive_buffer_position: This variable will keep track of which bytes in the receive buffer
// we have already processed. It is the offset (0-31) of the next byte
// in the buffer to process.
unsigned char receive_buffer_position = 0;
// send_buffer: A buffer for sending bytes on PD1/TXD.
char send_buffer[32];
// wait_for_sending_to_finish: Waits for the bytes in the send buffer to
// finish transmitting on PD1/TXD. We must call this before modifying
// send_buffer or trying to send more bytes, because otherwise we could
// corrupt an existing transmission.
void wait_for_sending_to_finish()
while(!serial_send_buffer_empty());
// process_received_byte: Responds to a byte that has been received on
// PD0/RXD. If you are writing your own serial program, you can
// replace all the code in this function with your own custom behaviors.
void process_received_byte(char byte)
switch(byte)
// If the character 'G' is received, turn on the green LED.
case 'G':
green_led(1);
break;
// If the character 'g' is received, turn off the green LED.
case 'g':
green_led(0);
break;
// If the character 'c' is received, play the note c.
case 'c':
play_from_program_space(PSTR("c16"));
break;
// If the character 'd' is received, play the note d.
case 'd':
play_from_program_space(PSTR("d16"));
break;
// If any other character is received, change its capitalization and
// send it back.
default:
wait_for_sending_to_finish();
send_buffer[0] = byte ^ 0x20;
serial_send(send_buffer, 1);
break;
void check_for_new_bytes_received()
while(serial_get_received_bytes() != receive_buffer_position)
// Process the new byte that has just been received.
process_received_byte(receive_buffer[receive_buffer_position]);
// Increment receive_buffer_position, but wrap around when it gets to
// the end of the buffer.
if (receive_buffer_position == sizeof(receive_buffer)-1)
else
receive_buffer_position++;
int main()
// Set the baud rate to 9600 bits per second. Each byte takes ten bit
// times, so you can get at most 960 bytes per second at this speed.
serial_set_baud_rate(9600);
// Start receiving bytes in the ring buffer.
serial_receive_ring(receive_buffer, sizeof(receive_buffer));
while(1)
wait_for_sending_to_finish(); //send repeatingly without buttons
memcpy_P(send_buffer, PSTR("Hi there!\r\n"), 11);
serial_send(send_buffer, 11);
delay_ms(1000);
// Deal with any new bytes received.
check_for_new_bytes_received();
// If the user presses the middle button, send "Hi there!"
// and wait until the user releases the button.
if (button_is_pressed(MIDDLE_BUTTON))
// Wait for the user to release the button. While the processor is
// waiting, the OrangutanSerial library will take care of receiving
// bytes using the serial reception interrupt. But if enough bytes
// arrive during this period to fill up the receive_buffer, then the
// older bytes will be lost and we won't know exactly how many bytes
// have been received.
wait_for_button_release(MIDDLE_BUTTON);
For reading the serial I use the Pololu programmer attached to GND, TX and RX of my Baby-O
I tried some other examples but nothing was successful.
I created this with Atmel Studion 6.2 and after creation of a new project I copied the software from the library description documented on the pololu website. Does this create an omission. Is it possible to open this example directly from Atmel Studio?
