I have finished coding the reader for an HM55B and thought some of you may find it helpful. There was a good bit if information for using this compass module with Arduinos and Basic Stamps, but not much for Orangutans. So here is my solution…
READ COMPASS ANGLE FROM THE PARALLAX HM55B DIGITAL COMPASS WITH THE POLOLU BABY ORANGUTAN 328P
MAJORITY OF PROGRAM LOGIC: kiilo@kiilo.org WHO WROTE IT FOR THE ARDUINIO
MODIFIED TO RUN ON THE BABY O BY ME: scottfromscott@bellsouth.net
SEE THE flash_angle() FUNCTION FOR AN EXPLANATION OF HOW THE RED USER LED FLASHES THE CURRENT ANGLE
REFERENCES:
http://www.parallax.com/Portals/0/Downloads/docs/prod/compshop/HM55BModDocs.pdf -- compass documentation
http://www.parallax.com/Store/Sensors/CompassGPS/tabid/173/ProductID/98/List/0/Default.aspx?SortField=ProductName,ProductName -- product page
http://arduino.cc/playground/HM55B -- killo's Arduino version
https://forum.pololu.com -- general orangutan help
https://www.pololu.com/docs/0J14 -- Baby O user's guide
https://www.pololu.com/docs/pdf/0J20/pololu_avr_library.pdf
https://www.pololu.com/docs/pdf/0J18/avr_library_commands.pdf
#define F_CPU 20000000UL // Baby Orangutan frequency (20MHz)
#include <math.h>
#include <avr/io.h>
#include <util/delay.h> // uses F_CPU to achieve us and ms delays
#include <pololu/orangutan.h>
#include <stdlib.h>
// data connections:
// BABY O PINS <==> HM55B PINS
// PB0:IO_B0 <==> #4:CLK
// PB1:IO_B1 <==> #5/Enable
// PB2:IO_B2 <==> #1:Dout,#2:Din
// orangutan library defines used:
// for set_digital_output(), LOW, HIGH
// for set_digital_input() -- PULL_UP_ENABLED - enable pull-up resistor
float compass_angle = 999; // global variable available for other modules use
// for calibration: print out the compass 16-segment compass template at
// http://www.parallax.com/Portals/0/Downloads/docs/prod/compshop/HM55BModDocs.pdf
// line up north with a pocket compass and tape the template to a table
// this compass outputs negative angles for all westerly directions (180..359 -> -180..-1)
// so label the template as follows:
// 180(-180), 202.5(-157.5), 225(-135), 247.5(-112.5), 270(-90), 292.5(-67.5), 315(-45), 337.5(-22.5)
// set the Baby O powered HM55B in position facing south on compass template
// set calibrate_mode below to 1, then build and run this program
// you will now determine the compass reading and offset for each of 16 angles:
// starting with 180 degrees, read and write down the template angle, the compass reading
// and the offset. Repeat for all 16 angles. The offset for the reading will be a + or -
// number added to the reading to match the template angle-- eg. for a template angle of -90,
// where the reading is -115, the offset would be 25 -- -90 = -115 + 25
// now set calibrate_mode to 1 and complete the procedure above.
// Next, enter these values in the raw[] and offsets[] arrays in the corrected() function below
// the raw[] array is filled left to right, in negative to positive angles order
// the arrays are linked by their indices -- eg. offsets[2] goes with raw[2]
// in addition to the 16 values you just entered in each array above, you must do the following:
// add -180 at the beginning and 180 at the end of the raw[] array declaration;
// eg. => int raw[18] = {-180, ...(your 16 values)..., 180};
// you must also add corresponding offset values for these to the offsets[] array
// which can easily be calculated with any spreadsheet program as follows:
// the offset for for -180 degrees...
// col A: template angle; col B: reading; col c: offset
// A1: 157.5, B1: (reading for 157.5), C1: (offset)
// B2: -180, C2: =(B2-B1)*(C3-C1)/(B3-B1)+C1
// A3: -180, B3: (reading for -180), C3: (offset)
// the offset for for 180 degrees...same as above but change B2 to 180
// so if offset for -180 is -4.2 and -23 for 180, then your offsets array declaration would look as follows
// eg. => int offsets[18] = {-4.2, ...(your 16 offsets)..., -23};
// once your arrays are complete you may reset calibrate_mode to 0 below
// and rebuild and test your completed program which should more accurately
// display the compass angles
int calibrate_mode = 0; //0 = use linear interpolation tables; 1 = flash raw angle values for calibration
//// FUNCTIONS
void delayms( uint16_t millis )
while(millis)
_delay_ms(1);
millis--;
void ShiftOut(int Value, int BitsCount)
for(int i = BitsCount; i >= 0; i--)
set_digital_output(IO_B0, HIGH);
if ((Value & 1 << i) == ( 1 << i)) set_digital_output(IO_B2, HIGH); // 1
else set_digital_output(IO_B2, LOW); // 0
set_digital_output(IO_B0, LOW);
delayMicroseconds(1);
int ShiftIn(int BitsCount)
int ShiftIn_result, i;
ShiftIn_result = 0;
set_digital_input(IO_B2, PULL_UP_ENABLED);
for(i = BitsCount; i >= 0; i--)
if (is_digital_input_high(IO_B2)) ShiftIn_result = (ShiftIn_result << 1) + 1;
else ShiftIn_result = (ShiftIn_result << 1) + 0;
if ((ShiftIn_result & 1 << 11) == 1 << 11) ShiftIn_result = (0B11111000 << 8) | ShiftIn_result;
return ShiftIn_result;
void setup()
set_digital_output(IO_B1, HIGH); // not enabled initially
set_digital_output(IO_B0, LOW); // clock is low initially
void HM55B_Reset()
set_digital_output(IO_B1, LOW);
ShiftOut(0B0000, 3); // send nibble of zeros
void HM55B_StartMeasurementCommand()
ShiftOut(0B1000, 3);
int HM55B_ReadCommand()
int result = 0;
ShiftOut(0B1100, 3);
result = ShiftIn(3);
return result;
float get_compass_angle()
float X_Data = 0, Y_Data = 0, angle = 0; // initialize to avoid compiler warning
int HM55B_result; // status flag
HM55B_StartMeasurementCommand(); // necessary!!
delayms(40); // the data is 40ms later ready
HM55B_result = HM55B_ReadCommand();
while(HM55B_result != 0B1100) HM55B_result = HM55B_ReadCommand(); // poll until ready status
X_Data = ShiftIn(11); // Field strength in X
Y_Data = ShiftIn(11); // and Y direction
set_digital_output(IO_B1, HIGH); // ok deselect chip
angle = 180 * (atan2(-1 * Y_Data , X_Data) / M_PI);
return(angle);
// I added the next 2 modules to use the red LED to aid reading and calibrating the compass
// If you don't need them, delete them and flash_angle() and delayms() references from main()
void flash_digit_value(int digit)
// flash LED 'digit value' times for each digit in angle
int counter;
if(digit==0) digit = 10; // special case for 0
for(counter=1;counter<=digit;counter++)
set_digital_output(IO_D1, HIGH); // LED on
delayms(200);
set_digital_output(IO_D1, LOW); // LED off
delayms(200);
delayms(1000); // indicates end of digit
void flash_angle(float angle)
// LED flashes indicate angle in degrees 0..359 by default
// 1 flash -> 1, 2 flashes -> 2, .. 9 flashes -> 9, BUT 10 flashes -> 0 (special case)
// ex. angle = 037 degrees -> 10 flashes + pause + 3 flashes + pause + 7 flashes + pause
// ex. angle = -037 degrees (same as above but followed by 1 flash for - sign)
// (readings repeat every 6 seconds)
int ones, tens, hundreds;
int uangle = abs(angle);
hundreds = (int)(uangle/100);
tens = (int)((uangle - hundreds*100)/10);
ones = uangle - tens*10 - hundreds*100;
flash_digit_value(hundreds);
flash_digit_value(tens);
flash_digit_value(ones);
if(angle<0) flash_digit_value(1); // indicate negative angle
float adjusted(float myangle)
// adjust raw angle reading by adding an offset
// these are values from my testing, yours will be different
// 16 offsets are determined by comparing template angles with HM55B readings; the first and last offsets
// are determined by linear interpolation
// { -180, ... your 16 readings here ..., 180);
float raw[18] = { -180,-175, -152, -137,-126,-115,-106,-99, -89, 9, 68, 90, 100,111, 125,141, 164, 180};
float offsets[18] ={ -4.98, -5, -5.5, 2,13.5, 25,38.5, 54, 66.5,-9,-45.5,-45,-32.5,-21,-12.5, -6,-6.5,-5.83};
// {-4.98, ..., -5.83} these two values computed with spreadsheet
int index = 0;
float offset;
for(index=17;index>0;index--) if(myangle>=raw[index-1]) break;
// do linear interpolation...
offset = (myangle-raw[index-1])*(offsets[index]-offsets[index-1])/(raw[index]-raw[index-1])+offsets[index-1];
if(calibrate_mode) return(myangle); // return raw angle for calibration
else return(myangle+offset<0?myangle+offset+360:myangle+offset); // return calibrated angle 000..359
int main()
int reading;
while(1)
compass_angle = 0;
for(reading=1;reading<=100;reading++) //get 100 readings, then average...
setup();
HM55B_Reset();
compass_angle += get_compass_angle();
compass_angle /= 100;
// now lookup the angle in the lookup table...
compass_angle = adjusted(compass_angle);
flash_angle(compass_angle);
delayms(2000); // pause before next reading
return 0;
Thanks to David at the Pololu forum for debugging help
