I set myself on a new venture today, to send a character from Arduino, through Serial and than to read that on Baby-O. Baby-O should blink Red LED when it recognizes the sent character. Now, I did only minimal changes to the existing code I found in examples. I did connect RX to TX and TX to RX and Arduino ground to Baby-O ground.
This is Arduino code, it simply sends letter ‘B’ every 3 seconds to Serial. I tried both Serial.print(‘B’); and Serial.write(66); to no avail:
#include <LiquidCrystal.h>
byte incomingByte = 'B'; // Arduino receiving incoming serial data into int variable.
// Initialize the library for the LCD display.
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
void setup() {
// Set up the LCD:
lcd.begin(16, 2);
// Print startup message to LCD.
lcd.print("OK, 9600 baud");
delay(2000); // waits for a two seconds,
// Prepare the Serial.
Serial.begin(9600);
Serial.flush();
void loop() {
///Serial.print(incomingByte); // Transmit received character back to Serial.
Serial.write(66);
delay(3000); // Wait a second or two.
The stuff for Baby-O is unchanged, apart from recognition of the character ‘B’ in switch statement:
#include <pololu/orangutan.h>
// receive_buffer: A ring buffer that we will use to receive bytes on PD0/RXD.
// The OrangutanSerial library will put received bytes in to
// the buffer starting at the beginning (receiveBuffer[0]).
// After the buffer has been filled, the library will automatically
// start over at the beginning.
char receive_buffer[32];
// receive_buffer_position: This variable will keep track of which bytes in the receive buffer
// we have already processed. It is the offset (0-31) of the next byte
// in the buffer to process.
unsigned char receive_buffer_position = 0;
// send_buffer: A buffer for sending bytes on PD1/TXD.
char send_buffer[32];
// My function added to show some reaction, on Baby-O, to received input:
void on_input_blink_red_x3() {
red_led(1); // red LED on
delay_ms(500); // waits for a second
red_led(0); // red LED off
void on_input_blink_red_x2() {
// wait_for_sending_to_finish: Waits for the bytes in the send buffer to
// finish transmitting on PD1/TXD. We must call this before modifying
// send_buffer or trying to send more bytes, because otherwise we could
// corrupt an existing transmission.
void wait_for_sending_to_finish() {
while(!serial_send_buffer_empty());
// process_received_byte: Responds to a byte that has been received on
// PD0/RXD. If you are writing your own serial program, you can
// replace all the code in this function with your own custom behaviors.
void process_received_byte(char byte) {
switch(byte) {
// If the character 'B' is received, turn on the green LED.
case 'B':
on_input_blink_red_x3();
break;
// If the character 'b' is received, turn off the green LED.
case 'b':
on_input_blink_red_x2();
break;
// If any other character is received, change its capitalization and
// send it back.
default:
wait_for_sending_to_finish();
send_buffer[0] = byte ^ 0x20;
serial_send(send_buffer, 1);
break;
void check_for_new_bytes_received() {
while(serial_get_received_bytes() != receive_buffer_position) {
// Process the new byte that has just been received.
process_received_byte(receive_buffer[receive_buffer_position]);
// Increment receive_buffer_position, but wrap around when it gets to
// the end of the buffer.
if (receive_buffer_position == sizeof(receive_buffer)-1) {
} else {
receive_buffer_position++;
int main() {
// Set the baud rate to 9600 bits per second. Each byte takes ten bit
// times, so you can get at most 960 bytes per second at this speed.
serial_set_baud_rate(9600);
// Start receiving bytes in the ring buffer.
serial_receive_ring(receive_buffer, sizeof(receive_buffer));
while(1) {
// Deal with any new bytes received.
check_for_new_bytes_received();
// If the user presses the middle button, send "Hi there!"
// and wait until the user releases the button.
if (button_is_pressed(MIDDLE_BUTTON)) {
memcpy_P(send_buffer, PSTR("Hi there!\r\n"), 11);
serial_send(send_buffer, 11);
// Wait for the user to release the button. While the processor is
// waiting, the OrangutanSerial library will take care of receiving
// bytes using the serial reception interrupt. But if enough bytes
// arrive during this period to fill up the receive_buffer, then the
// older bytes will be lost and we won't know exactly how many bytes
// have been received.
wait_for_button_release(MIDDLE_BUTTON);
Middle button part of the code is still there but it does nothing.
Can anybody help get Arduino and Baby-O talk through Serial?
