How do I change the PWM Freq in my project to eliminate the motor whine? I’m building in Arduino, and using the “OrangutanMotors.h” library.
Thanks a million for the help!
[code]#include <OrangutanLEDs.h>
#include <OrangutanAnalog.h>
#include <OrangutanMotors.h>
OrangutanAnalog analog;
OrangutanLEDs leds;
OrangutanMotors motors;
void setup() {}
void loop() {
// note that the following line could also be accomplished with:
// int pot = analog.read(7);
int pot = analog.readTrimpot(); // determine the trimpot position
int motorSpeed = pot/2-256; // turn pot reading into number between -256 and 255
if(motorSpeed == -256)
motorSpeed = -255; // 256 is out of range
motors.setSpeeds(motorSpeed, motorSpeed);
int ledDelay = motorSpeed;
if(ledDelay < 0)
ledDelay = -ledDelay; // make the delay a non-negative number
ledDelay = 256-ledDelay; // the delay should be short when the speed is high
leds.red(HIGH); // turn red LED on
delay(ledDelay);
leds.red(LOW); // turn red LED off
delay(ledDelay);
[/code]
