I’m attempting to program with the pololu usb programing using my original code I’ve used with a serial programmer. The MCU is a atmega8. The make file I’m using requires a AVRDUDE_PROGRAMMER option and I’m can’t seem to find out what to put for the pololu usb Programmer. Is there one in the avrdude list of supported programmers I should substitute with?
[quote]abcmini ABCmini Board, aka Dick Smith HOTCHIP
alf Nightshade ALF-PgmAVR,
nightshade.homeip.net/
arduino Arduino board, protocol similar to STK500 1.x
atisp AT-ISP V1.1 programming cable for AVR-SDK1 from,
micro-research.co.th/
avr109 Atmel AppNote AVR109 Boot Loader
avr910 Atmel Low Cost Serial Programmer
avr911 Atmel AppNote AVR911 AVROSP (an alias for avr109)
avrisp Atmel AVR ISP (an alias for stk500)
avrisp2 Atmel AVR ISP mkII in ISP mode, in PDI mode for ATxmega devices, or in TPI mode for ATtiny4/5/9/10
avrispmkII Atmel AVR ISP mkII (alias for stk500v2)
avrispv2 Atmel AVR ISP, running a version 2.x firmware (an alias for stk500v2)
bascom Bascom SAMPLE programming cable
blaster Altera ByteBlaster
bsd Brian Dean’s Programmer,
bsdhome.com/avrdude/
buspirate The Bus Pirate
butterfly Atmel Butterfly Development Board
c2n232i C2N232I, reset=dtr sck=!rts mosi=!txd miso=!cts,
ktverkko.fi/~msmakela/8bit/c … ex.en.html
dapa Direct AVR Parallel Access cable
dasa serial port banging, reset=rts sck=dtr mosi=txd miso=cts
dasa3 serial port banging, reset=!dtr sck=rts mosi=txd miso=cts
dragon_dw AVR Dragon in debugWire mode
dragon_hvsp AVR Dragon in high-voltage serial programming mode
dragon_isp AVR Dragon in ISP mode
dragon_jtag AVR Dragon in JTAG mode
dragon_pdi AVR Dragon in PDI mode
dragon_pp AVR Dragon in (high-voltage) parallel programming mode
dt006 Dontronics DT006
ere-isp-avr ERE ISP-AVR,
ere.co.th/download/sch050713.pdf
frank-stk200 Frank’s STK200 clone,
electropol.free.fr/spip/spip.php?article15
futurlec Futurlec.com programming cable
jtag1 Atmel JTAG ICE mkI, running at 115200 Bd
jtag1slow Atmel JTAG ICE mkI, running at 19200 Bd
jtag2 Atmel JTAG ICE mkII, running at 115200 Bd
jtag2avr32 Atmel JTAG ICE mkII in AVR32 mode.
jtag2dw Atmel JTAG ICE mkII in debugWire mode.
jtag2fast Atmel JTAG ICE mkII, running at 115200 Bd
jtag2isp Atmel JTAG ICE mkII in ISP mode.
jtag2pdi Atmel JTAG ICE mkII in PDI mode.
jtag2slow Atmel JTAG ICE mkII (default speed 19200 Bd)
jtagmkI Atmel JTAG ICE mkI, running at 115200 Bd
jtagmkII Atmel JTAG ICE mkII (default speed 19200 Bd)
jtagmkII_avr32 Atmel JTAG ICE mkII in AVR32 mode.
mib510 Crossbow MIB510 programming board
pavr Jason Kyle’s pAVR Serial Programmer
picoweb Picoweb Programming Cable,
picoweb.net/
pony-stk200 Pony Prog STK200
ponyser design ponyprog serial, reset=!txd sck=rts mosi=dtr miso=cts
siprog Lancos SI-Prog,
lancos.com/siprogsch.html
sp12 Steve Bolt’s Programmer
stk200 STK200
stk500 Atmel STK500, probing for either version 1.x or 2.x firmware
stk500hvsp Atmel STK500 in high-voltage serial programming mode(version 2.x firmware only)
stk500pp Atmel STK500 in parallel programming mode (version 2.xfirmware only)
stk500v1 Atmel STK500, running a version 1.x firmware
stk500v2 Atmel STK500, running a version 2.x firmware
stk600 Atmel STK600 in ISP mode, in PDI mode for ATxmega devices, or in TPI mode for ATtiny4/5/9/10
stk600hvsp Atmel STK600 in high-voltage serial programming mode
stk600pp Atmel STK600 in parallel programming mode
usbasp USBasp,
fischl.de/usbasp/
usbtiny USBtiny simple USB programmer,
ladyada.net/make/usbtinyisp/
xil Xilinx JTAG cable[/quote]
Thank you for your time.
