Microsoft Windows [Version 10.0.18363.1139]
© 2019 Microsoft Corporation. All rights reserved.
C:\Users\Kevin>pavr2cmd -s
Name: Pololu USB AVR Programmer v2.1
Serial number: 00320459
Firmware version: 1.02
Programming port: COM6
TTL port: COM5
Settings:
ISP frequency (kHz): 114
Max ISP frequency (kHz): 1714
Regulator mode: auto
VCC output: Disabled
VCC output indicator: Blinking
Line A function: None
Line B function: DTR
VCC/VDD maximum range (mV): 896
VCC 3.3 V minimum (mV): 2720
VCC 3.3 V maximum (mV): 3872
VCC 5 V minimum (mV): 4128
VCC 5 V maximum (mV): 5856
STK500 hardware version: F
STK500 software version: 2.A
Results from last programming: N/A
Current status:
Target VCC (mV): 288
Programmer VDD (mV): 2976
VDD regulator set point: 3.3 V
Last device reset: Brown-out reset
This is the output of pavr2cmd -s
When I try the Configuration Utility, it will not connect. I get the error message “No AVR Programmer detected. … etc.”
My questions are: 1. how do I overcome the brownout reset, and 2. How do I enable Vcc Output?
Many thanks in advance,
Kevington
