What do you mean? It looks like the current version of Atmel Studio is 6.0 build 1996, and I recently updated the installer to work with that version.
If you use the default install locations, those files should be installed in subdirectories of C:\libpololu-avr and C:\Program Files (x86)\Atmel\Atmel Studio 6.0\extensions\Atmel\AVRGCC\3.4.0.65\AVRToolchain\avr . The installer for our library should take care of that for you.
You should really use the New Project templates we provide so you don’t need to worry about that, but you can also make your own template from an existing project once you configure it correctly. Check the file menu for something like “Export template…”
Thanks so much for the reply. The error is in the AVRGCC version, mine is 3.4.1.95. The AVRStudio is 1996 service pack 2, so thats not where I got the error.
I try your tip and see if I can work around or figure out the AVRGCC path problem.
Anxious to get (re-started) with my 3pi. Bought it long ago when my brain worked bettter (I was still working). Gonna try to kickstart it and learn a bit more before I kick the bucket.
