Hello, I am trying to use the virtual serial port on the AVR usb programmer to output to a putty terminal session.
This is on a ATMEGA168. The sample code I found is below. I am using the built-in 8Mhz clock on the AVR.
I am getting data transmitted, back to putty, but it is garbled. I have putty also setup for 9600/8/N/1.
Any hints on what I am missing?
void serial_init(unsigned int bittimer)
/* Set the baud rate */
UBRR0H = (unsigned char) (bittimer >> 8);
UBRR0L = (unsigned char) bittimer;
/* set the framing to 8N1 */
UCSR0C = (3 << UCSZ00);
/* Engage! */
UCSR0B = (1 << RXEN0) | (1 << TXEN0);
void serial_write(unsigned char c)
while ( !(UCSR0A & (1 << UDRE0)) )
UDR0 = c;
#define SPEED 9600
int main (void)
serial_init( ( F_CPU / SPEED / 16 ) - 1);
while (1) {
serial_write('A');
_delay_ms(2);
return 0;
