Does anyone have a Auto Pan, Manual Tilt, Joystick override, Speed controlled program?
Yes, its a big ask and I don’t know how to make it work or what to use.
What is it for - I am wanting to build a Pan Tilt Assembly to hold a Camera and for it to perform in Auto Mode and then be deselected and used by a joystick in Manual Mode.
Auto Mode
- Pan left and right automatically
- Extend or reduce pan left and right in the auto mode
(I was thinking by keypad buttons to a script, rotary encoder or rotary or slide potentiometers, which ever is use friendly) - Increase or decrease speed again by pre program buttons, rotary encoder or rotary or slide potentiometers
- Minor manual tilt adjustment, a trim or + – button. Prefer not to use Joystick, see below.
Manual Mode
- Joystick control - a joystick signal that could then stop the micro controller being in auto mode, or power off via a manual press button switch and then manually control from the joystick, even if it was a separate system that was configured in, “In parallel”
Any assistance, code, thoughts on what to use (Servo or stepper motor and possibly gearbox) would be appreciated.
Thanks
David
