I have the Mini Maestro and I’m looking to control the Jaw movement on a skeleton model. I’ve seen a lot of discussion on this topic, but the answer seems to be another software program to control the movement. I believe this will solve the issue.
Since the control signal will be audio, the volume of the audio will control the opening of the jaw; the louder the signal, the wider the jaw, the softer the signal, the narrower the jaw. To make this happen, I will be using an audio VU meter. The VU meter runs off 5 volts, the same as the power to the Mini Maestro. There are 5 LED’s in the meter. As the volume gets louder it turns on each one of the LED’s (they continue to stay on until the volume lowers below that channel’s threshold). I want to use the signals from these 5 separate channels as inputs to five of the input channels in the Mini Maestro. For example, they can be interpreted as:
LED 1= 10% jaw opening
LED 2= 25% jaw opening
LED 3= 50% jaw opening
LED 4= 70% jaw opening
LED 5= 95% jaw opening
I don’t know how to write the code to make this happen and I’m seeking help. Also, I read in one of the posts to add hysteresis to reduce the servo from chattering and I don’t know if this will need it or not but it if does, your help would be greatly appreciated.
I appreciate your help. Thank you.
It is not entirely clear to me what kind of interface your audio board is using, but from your description, it sounds like it essentially has 5 digital outputs that are subsequently driven high for louder sounds (i.e. for the loudest sound, all 5 will be high and for the softest sound only the first one will be high). If that is the case, you should be able to use 5 channels on the Maestro to read those inputs like you described. A series of chained IF statements is probably the easiest way to handle that, for example:
#this code is for a servo on Maestro channel 0 and inputs on Maestro channels 1-5
begin
5 get_position 512 if 8000 #if input 5 is high, put 8000 on the stack
else if 4 get_position 512 if 7600 #otherwise, if input 4 is high put 7600 on the stack. . .
else if 3 get_position 512 if 7200
else if 2 get_position 512 if 6800
else if 1 get_position 512 if 6400
else 6000 #no inputs are high, put 6000 on the stack
endif
endif
endif
endif
endif
0 servo #set target position for channel 0 to value on stack
repeat
You will likely need to adjust the servo positions at each loudness level, but that code should give you something to get started with.
Hi Brandon, thank you for your help, I really appreciate it. Since I’m a total noob, in the first line, 512 if 8000, does the “8000” mean the radial location for the servo?
This is the VU meter, the output is analog, but it’s basically going full on for each channel.
https://www.amazon.com/dp/B0BLGK7YYD?ref=ppx_yo2ov_dt_b_fed_asin_title
Thank you
8000 is the target position being sent to the servo. The servo command in the Maestro script uses units of quarter-microseconds, so sending a target position of 8000 corresponds to a pulse width of 2000 µs.
Unfortunately, I do not see any datasheet or explanation of how the board works on that Amazon page, but if you get it working with the Maestro I would be interested in seeing your results!
Thank you for the fast reply Brandon. I will indeed share it with you. I looked over the forum and this is a common question. I’d like to get a really good solution for this as there are many looking to solve this.
If there is erratic or jerky movement, is there a way to add acceleration or deceleration to the code to smooth the response for the servo?
You can set an acceleration and speed limit for the servo channel in the “Channel Settings” tab of the Maestro Control Center. You can learn more about the Speed and Acceleration settings in the “Channel Settings” section of the Maestro user’s guide.
Alternatively, you can set a temporary speed or acceleration limit using the SPEED and ACCELERATION commands in your script. If you do it this way, please note that all subsequent movements on the specified servo channel will use the new speed and acceleration limit until it is reset or power cycled.
By the way, erratic jerky movement can often be a sign of a power issue (i.e. an inadequate power supply) or an underpowered servo. So, if it continues even after introducing speed and acceleration limits, you might try looking into that further.
Thank you Brandon. I will be working on it this weekend.
The reason why I mentioned ‘jerky’ movement is because when a servo moves from one point to another, it does it very quickly and appears ‘jerky’ to say a jaw, head or limb. In animation or ‘real life movement’ there are acceleration and deceleration curves that smoothes out the movement making it more natural. In animation, they use bezier curves to smooth in and out the movements.
Are there any kind of equations that can be used in the code that can do some sort of exponential function that can possibly be put into these movements to simulate a bezier curve?
This can be used in a number of applications, not just animatronics, making robotics look more realistic. Just thinking out loud…
Unfortunately, the Maestro does not have any special support exponential speed profiles like that. With an acceleration limit set it will essentially use a trapezoidal profile.
Thank you Brandon, I appreciate your time. I’ll check in with you about my progress.
Hi Brandon, I found this example which might work.
I’m not sure if the code is the same for the Maestro as it is for the arduino, but here’s an example of how this guy got smoothing to work. If this code does work for Maestro, again, I’m a total noob, what would the code look like if it was added to your example at the top of the page?
Thank you, I appreciate it!
Adding that kind of behavior to the example in my previous post would be slightly more complicated than I would generally recommend for someone new to the Maestro scripting language. Have you tried using the Maestro’s acceleration and speed limits as I described before?
If you want to approximate it, you could try adding this smoothMoveServo0 subroutine to your script and replace 0 servo in my previous code with smoothMoveServo0:
sub smooth_move_servo0
20 divide
0 get_position
0 begin dup 60 less_than while
rot rot
20 divide 19 times
1 peek plus dup
0 servo
10 delay
rot 1 plus
repeat
drop drop drop
return
However, please note that because of the way it is written it will take at least 600ms to update the servo position, during which your script will not respond to new inputs. Also, since the Maestro scripting language does not use floats and truncates the remainder, it will not actually reach the specified target. If you need to correct for this, you could increase your targets to values higher than what you actually want. Alternatively, you could get a bit closer by adjusting the code, but it would make it more complicated.
Thank you Brandon for the reply.
What I want to show is that by using one Maestro, I can control three different animatronic props.
One will have head and jaw movement, but another will have head, shoulders, arm and jaw movement.
I’d like to make a video of it to show others on this forum.
With that said, it’s not only jaw/audio movement I’m looking for, but can I be able to use this smoothing code for movements like head/shoulder/arm turn since I’m not relying on audio for the input?
Thank you.
The Maestro’s built-in acceleration and speed limits on each channel are automatically considered whenever you update a channel’s target position. So, if that works for you, it would be the easiest solution.
Applying smoothing in a Maestro script like I showed in my previous post but to multiple channels would be a lot more complicated, and in general, you would probably be better off using an Arduino to calculate the target positions and updating the Maestro via TTL serial.
Hi Brandon,
The speed adjustment has helped tremendously! Thank you.
The speed is fairly straightforward, the lower the number, the slower the servo.
I haven’t been able to see a difference with the acceleration, how does that work?
Thank you
The acceleration controls how quickly the speed can ramp up. Similarly to how the speed setting works, the lower the value, the slower the acceleration. You can find more specific details in the “Channel Settings” section of the Maestro user’s guide.
The effect of the acceleration is easier to see when you have higher speed limits (or no speed limit) set. Additionally, please note that the acceleration setting is also used to decelerate the servo as it approaches the target position. So, a wider movement will also make it more noticeable. For example, if you move the servo from a target of 1000μs to 2000μs with the speed set to 50 and the acceleration set to 2, you should be able to see it noticeably ramp up to speed before decelerating to the target position. Also, because of the way the speed and acceleration limits work, the Maestro needs to know the current position of the servo to apply the speed and acceleration limits, so they are not used when a servo channel is first enabled (which is also the case for the first move directly after a power-up).
Hi Brandon,
I think the best way to do this is with an analog input. I’ve been able to slow down the signal so it’s a very smooth waveform.
Since I’d be looking at a single analog input, what coding do I need to use to control a servo?
Thank you, I appreciate your help!
You can find a few different examples for controlling a servo from an analog input in different ways in the “Example Scripts” section of the Maestro user’s guide, specifically under the “Using an analog input to control servos” heading.
