Assistance with choosing a silent motor
Subject: Looking for a silent, low-current DC gearmotor alternative to N20 298:1 LP
Hi everyone,
I need help finding a virtually silent DC motor (preferably with a gearbox) for a kinetic art project. The motor uses a friction drive to slowly rotate a decorative disc inside a wooden frame.
Current setup & specs:
  • Motor: Pololu 298:1 Micro Metal Gearmotor LP
  • Operating voltage: 2V DC
  • Drive geometry: 40 mm friction drive wheel rotating a 210 mm outer rim (approx. 5.25:1 reduction)
Electrically and mechanically, this setup works great—my project runs on very low currents, and the torque and speed at 2V are spot on. However, the metal gearbox itself generates way too much noise under load inside the wooden enclosure (which acts like a soundboard), and adding vibration isolation hasn’t solved the issue.
Could you recommend a much quieter alternative that meets these criteria:
  • Standard brushed/coreless DC (I want to avoid redesigning the electronics for a BLDC setup)
  • Very low current draw at ~2V (comparable to the N20 LP series)
  • Compact size (to fit inside a slim wooden frame)
  • Near-silent operation under light-to-moderate load
For example, would switching to a lower gear ratio (like 75:1 or 50:1 LP) paired with a much smaller drive wheel (e.g., 8–10 mm) noticeably reduce the gearbox noise while keeping the same final speed, or should I look into a completely different motor/gearbox type (such as plastic gears or a planetary gearbox)?
Thanks in advance for your advice!
Hi Vladislav, nice project — and this noise problem is a familiar one with small high-ratio metal gearboxes. Most of the whine comes from the fastest gear meshes, the motor pinion and the first stages, and a wooden frame makes a very good soundboard, so it amplifies exactly that. Since vibration isolation hasn’t solved it, the noise is likely coming straight out of the gearbox itself rather than only through the mounts.
On your specific idea: switching to a 50:1 or 75:1 with a much smaller drive wheel probably won’t make it quieter, and it could make it louder. To keep the same rim speed with an 8–10 mm wheel instead of a 40 mm one, the output shaft has to spin about four times faster, and with the lower gear ratio the motor itself has to spin several times faster again. Gear noise rises with speed, so the higher motor RPM would likely cancel out any benefit from having fewer gear stages.
The things that usually help most for near-silent running are:
  • A plastic-gear gearbox instead of metal gears. Plastic teeth mesh much more quietly than metal ones, which is the single biggest difference in my experience. The trade-off is lower torque capacity and a little more backlash, but for a light kinetic disc that is usually fine.
  • A coreless motor if you can find one in a similar size. Coreless motors run smoother with less cogging vibration than a standard cored brushed motor, so there is less vibration to excite the frame.
  • Keeping the motor RPM low. That points toward a higher ratio and a larger drive wheel rather than a lower ratio and a smaller wheel, since the fastest meshes are the noisy ones.
  • A tiny amount of suitable gear grease on the gear teeth, which can take the edge off the whine. Keep grease away from the motor itself.
One question that would help narrow it down: roughly how fast does the rim need to turn? If it is very slow, a high-ratio plastic-gear motor running at 2 V would be the first thing I would try.
