#include <Wire.h>
#include <ZumoShield.h>
#include <NewPing.h>
#include <QTRSensors.h>
#define LED 13
#define QTR_THRESHOLD 1500
#define REVERSE_SPEED 225
#define TURN_SPEED 200
#define ATTACK_SPEED 300
#define FORWARD_SPEED 200
#define REVERSE_DURATION 250
#define TURN_DURATION 250
ZumoMotors motors;
Pushbutton button(ZUMO_BUTTON);
#define NUM_SENSORS 6
unsigned int sensor_values[NUM_SENSORS];
#define TRIGGER_PIN 4
#define ECHO_PIN 5
#define MAX_DISTANCE 200
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
ZumoReflectanceSensorArray sensors(QTR_NO_EMITTER_PIN);
void waitForButtonAndCountDown()
digitalWrite(LED, HIGH);
button.waitForButton();
digitalWrite(LED, LOW);
delay(3000);
void setup()
pinMode(LED, HIGH);
pinMode(TRIGGER_PIN, OUTPUT);
pinMode(ECHO_PIN, INPUT);
waitForButtonAndCountDown();
void loop()
if (button.isPressed())
motors.setSpeeds(0, 0);
button.waitForRelease();
//delay();
int distance = sonar.ping_cm();
sensors.read(sensor_values);
if (sensor_values[0] < QTR_THRESHOLD)
motors.setSpeeds(-REVERSE_SPEED, -REVERSE_SPEED);
delay(REVERSE_DURATION);
motors.setSpeeds(TURN_SPEED, -TURN_SPEED);
delay(TURN_DURATION);
motors.setSpeeds(FORWARD_SPEED, FORWARD_SPEED);
else if (sensor_values[5] < QTR_THRESHOLD)
motors.setSpeeds(-TURN_SPEED, TURN_SPEED);
else if (distance >= 1 && distance <= 15)
motors.setSpeeds(ATTACK_SPEED, ATTACK_SPEED);
else
This is my code above, changed to D-Pin 4 and 5 for my HC-SR04 sensor but this seems to be the part still causing me issues. when i disconnect the sensor, the motors work fine but i cant seem to figure out if its the conditions ive set thats causing me issues.
this is for my mini zumo robot, im using a zumo shield and an arduino uno.
