Hello!
I am trying to write a fairly simple program with Arduino and Pololu Maestro servo controller. I want ‘sequence 2’ to loop and ‘sequence 0’ and ‘sequence 1’ to play when their associated buttons are pressed. I can get the button presses to function correctly but when I try to introduce an if statement to play sequence 2 when nothing is pressed I get some unexpected results. Could someone please look this over and let me know what I am doing wrong. All help is greatly appreciated!
Thank you!
#include <PololuMaestro.h>
#ifdef SERIAL_PORT_HARDWARE_OPEN
#define maestroSerial SERIAL_PORT_HARDWARE_OPEN
#else
#include <SoftwareSerial.h>
SoftwareSerial maestroSerial(10,11);
#endif
MicroMaestro maestro(maestroSerial);
//MiniMaestro maestro(maestroSerial);
const int buttonPin = 2;
const int buttonPin2 = 3;
int buttonState = HIGH;
int buttonState2 = HIGH;
int MotorControl = 5;
void setup()
maestroSerial.begin(9600);
pinMode(buttonPin, INPUT_PULLUP);
pinMode(buttonPin2, INPUT_PULLUP);
pinMode(MotorControl, OUTPUT);
void loop()
buttonState = digitalRead(buttonPin);
buttonState2 = digitalRead(buttonPin2);
if(buttonState == HIGH && buttonState2 == HIGH){
//digitalWrite(MotorControl,LOW);
maestro.restartScript(02);
//delay(4000);
if (buttonState == LOW) {
//maestro.stopScript();
maestro.restartScriptWithParameter(0, 0);
digitalWrite(MotorControl,HIGH);
//delay(4000);
else {
if (buttonState2 == LOW) {
maestro.restartScriptWithParameter(01, 01);
//digitalWrite(MotorControl,HIGH);
//delay(4000);
0000: --
0000: --
0000: -- ### Sequence subroutines: ###
0000: --
0000: -- # Sequence 0
0000: -- sub Sequence_0
0000: 031AF401B4135E18800F800F800F7516401FAB190000000000000000 -- 500 5044 6238 3968 3968 3968 5749
001C: 83 -- 8000 6571 0 0 0 0 frame_0..11 # Frame 0
001D: 0304F401800F84 -- 500 3968 frame_6 # Frame 1
0024: 00 -- quit
0025: -- # Sequence 1
0025: -- sub Sequence_1
0025: 031AF401B4135E18800F800F800F7516800F800F0000000000000000 -- 500 5044 6238 3968 3968 3968 5749
0041: 83 -- 3968 3968 0 0 0 0 frame_0..11 # Frame 0
0042: 0304F401DB1384 -- 500 5083 frame_6 # Frame 1
0049: 0304F401800F84 -- 500 3968 frame_6 # Frame 2
0050: 0304F401C61484 -- 500 5318 frame_6 # Frame 3
0057: 0304F401800F84 -- 500 3968 frame_6 # Frame 4
005E: 00 -- quit
005F: -- # Sequence 2
005F: -- sub Sequence_2
005F: -- begin
005F: 031AF401B4135E18441C8E126414BA0F800F800F0000000000000000 -- 500 5044 6238 7236 4750 5220 4026
007B: 83 -- 3968 3968 0 0 0 0 frame_0..11 # Frame 0
007C: 0304F401401F85 -- 500 8000 frame_2 # Frame 1
0083: 0304F401800F85 -- 500 3968 frame_2 # Frame 2
008A: 0304F401841985 -- 500 6532 frame_2 # Frame 3
0091: 0304F401F31D85 -- 500 7667 frame_2 # Frame 4
0098: 0304F401800F85 -- 500 3968 frame_2 # Frame 5
009F: 0304F401401F85 -- 500 8000 frame_2 # Frame 6
00A6: 065F00 -- repeat
00A9: --
00A9: -- sub frame_0..11
00A9: 020B2A -- 11 servo
00AC: 020A2A -- 10 servo
00AF: 02092A -- 9 servo
00B2: 02082A -- 8 servo
00B5: 02072A -- 7 servo
00B8: 02062A -- 6 servo
00BB: 02052A -- 5 servo
00BE: 02042A -- 4 servo
00C1: 02032A -- 3 servo
00C4: 02022A -- 2 servo
00C7: 02012A -- 1 servo
00CA: 02002A -- 0 servo
00CD: 08 -- delay
00CE: 05 -- return
00CF: --
00CF: -- sub frame_6
00CF: 02062A -- 6 servo
00D2: 08 -- delay
00D3: 05 -- return
00D4: --
00D4: -- sub frame_2
00D4: 02022A -- 2 servo
00D7: 08 -- delay
00D8: 05 -- return
00D9: --
Subroutines:
Hex Decimal Address Name
00 000 0000 SEQUENCE_0
01 001 0025 SEQUENCE_1
02 002 005F SEQUENCE_2
03 003 00A9 FRAME_0..11
04 004 00CF FRAME_6
05 005 00D4 FRAME_2
