Hi
I’ve been working on a project that controls 6 servos with the Polulu 8 servo controller. I’m syncing the movement of my servos to each frame of a quicktime (25 fps) Using Max/msp. After much head scratching I’ve got it working with 3 servos, but now that I’ve got 6 running, the servos aren’t keeping up. I’m using the old SoftwareSerial library that can only run at 9600 baud. I’ve tried using the NewSoftwareSerial library (which can run at much higher baud rate) but I just get a red and green flashing light. Has anyone used the NewSoftwareSerial library? or could there be another reason for the problem? (I’ve included my code)
Any pointers would be greatly appreciated ( I’m afraid I’m still struggling with Arduino).
Kind regards Conor
// Pololu micro serial servo controller modes
// Software Serial from Arduino example by Tom Igoe
// put() (now position_absolute) & set_speed() functions found on pololu forums & modified
// mike crist 2009-01-03
#include <SoftwareSerial.h>
#define rxPin 2
#define txPin 3
// set up a new serial port
SoftwareSerial softSerial = SoftwareSerial(rxPin, txPin);
int i = 500;
void setup()
pinMode(rxPin, INPUT);
digitalWrite(txPin, HIGH); // keeps pololu board from getting spurious signal
pinMode(txPin, OUTPUT);
// set the data rate for the hardware serial port
Serial.begin(9600);
// set the data rate for the SoftwareSerial port
softSerial.begin(9600);
set_speed(0, 0);
set_speed(1, 0);
set_speed(2, 0);
set_speed(3, 0);
set_speed(4, 0);
set_speed(5, 0);
void loop()
Serial.flush();
char inputA[8];
char inputB[8];
char inputC[8];
char inputD[8];
char inputE[8];
char inputF[8];
memset(inputA, '\0', 8);
memset(inputB, '\0', 8);
memset(inputC, '\0', 8);
memset(inputD, '\0', 8);
memset(inputE, '\0', 8);
memset(inputF, '\0', 8);
byte inByte = '\0';
while(inByte != 'A') {
inByte = Serial.read(); // Wait for the start of the message
if(inByte == 'A') {
while(Serial.available() < 24) { // Wait until we receive 5 characters
for (int a=0; a < 24; a++) {
if( a >= 0 && a <= 3){
inputA[a] = Serial.read(); // Read the characters into an array
if( a >= 4 && a <= 7){
inputB[(a-4)] = Serial.read(); // Read the characters into an array
if( a >= 8 && a <= 11){
inputC[(a-8)] = Serial.read(); // Read the characters into an array
if( a >= 12 && a <= 15){
inputD[(a-12)] = Serial.read(); // Read the characters into an array
if( a >= 16 && a <= 19){
inputE[(a-16)] = Serial.read(); // Read the characters into an array
if( a >= 20 && a <= 23){
inputF[(a-20)] = Serial.read(); // Read the characters into an array
int numberA = atoi(inputA);
int numberB = atoi(inputB);
int numberC = atoi(inputC);
int numberD = atoi(inputD);
int numberE = atoi(inputE);
int numberF = atoi(inputF);
position_absolute(0, numberA);
position_absolute(1, numberB);
position_absolute(2, numberC);
position_absolute(3, numberD);
position_absolute(4, numberE);
position_absolute(5, numberF);
void position_absolute(byte servo, int angle)
//this function uses pololu mode command 4 to set absolute position
//servo is the servo number (typically 0-7)
//angle is the absolute position from 500 to 5500
unsigned int temp;
byte pos_hi,pos_low;
temp = angle & 0x1f80; //get bits 8 thru 13 of position
pos_hi = temp >> 7; //shift bits 8 thru 13 by 7
pos_low = angle & 0x7f; //get lower 7 bits of position
//Send a Pololu Protocol command
softSerial.print(0x80, BYTE); //start byte
softSerial.print(0x01, BYTE); //device id
softSerial.print(0x04, BYTE); //command number
softSerial.print(servo, BYTE); //servo number
softSerial.print(pos_hi, BYTE); //bits 8 thru 13
softSerial.print(pos_low, BYTE); //bottom 7 bits
void set_speed(byte servo, byte speedVal)
//this function uses pololu mode command 1 to set speed
//speedVal is servo speed (1=slowest, 127=fastest, 0=full)
//set speedVal to zero to turn off speed limiting
speedVal = speedVal & 0x7f; //take only lower 7 bits of the speed
softSerial.print(0x80,BYTE); //start byte
softSerial.print(0x01,BYTE); //device id
softSerial.print(0x01,BYTE); //command number
softSerial.print(servo,BYTE); //servo number
softSerial.print(speedVal,BYTE); //speed
