i want to drive a motor with an Arduino nano and a Adxl345, it use to work but now i got a serial error
on the JRK21V3. It should keep a basket horzontal for a handycapt person who needs oxygen.
I build this in 2016 and it worked. Now i have to build another one but it won`t function.
The code is below, can someone help me ?
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_ADXL345_U.h>
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11);
/* Assign a unique ID to this sensor at the same time */
Adafruit_ADXL345_Unified accel = Adafruit_ADXL345_Unified(12345);
float multiplier = 1 ; //change this value to adjust motor sensitivity, decimals are ok
int dir = 1; // change to -1 to invert direction
int outputValue = 0; // value output to the controller
int old_outputValue = 0;
byte command[2];
int bytesSent = 0;
void displaySensorDetails(void)
sensor_t sensor;
accel.getSensor(&sensor);
Serial.println("------------------------------------");
Serial.print ("Sensor: "); Serial.println(sensor.name);
Serial.print ("Driver Ver: "); Serial.println(sensor.version);
Serial.print ("Unique ID: "); Serial.println(sensor.sensor_id);
Serial.print ("Max Value: "); Serial.print(sensor.max_value); Serial.println(" m/s^2");
Serial.print ("Min Value: "); Serial.print(sensor.min_value); Serial.println(" m/s^2");
Serial.print ("Resolution: "); Serial.print(sensor.resolution); Serial.println(" m/s^2");
Serial.println("");
delay(500);
void displayDataRate(void)
Serial.print ("Data Rate: ");
switch(accel.getDataRate())
case ADXL345_DATARATE_3200_HZ:
Serial.print ("3200 ");
break;
case ADXL345_DATARATE_1600_HZ:
Serial.print ("1600 ");
break;
case ADXL345_DATARATE_800_HZ:
Serial.print ("800 ");
break;
case ADXL345_DATARATE_400_HZ:
Serial.print ("400 ");
break;
case ADXL345_DATARATE_200_HZ:
Serial.print ("200 ");
break;
case ADXL345_DATARATE_100_HZ:
Serial.print ("100 ");
break;
case ADXL345_DATARATE_50_HZ:
Serial.print ("50 ");
break;
case ADXL345_DATARATE_25_HZ:
Serial.print ("25 ");
break;
case ADXL345_DATARATE_12_5_HZ:
Serial.print ("12.5 ");
break;
case ADXL345_DATARATE_6_25HZ:
Serial.print ("6.25 ");
break;
case ADXL345_DATARATE_3_13_HZ:
Serial.print ("3.13 ");
break;
case ADXL345_DATARATE_1_56_HZ:
Serial.print ("1.56 ");
break;
case ADXL345_DATARATE_0_78_HZ:
Serial.print ("0.78 ");
break;
case ADXL345_DATARATE_0_39_HZ:
Serial.print ("0.39 ");
break;
case ADXL345_DATARATE_0_20_HZ:
Serial.print ("0.20 ");
break;
case ADXL345_DATARATE_0_10_HZ:
Serial.print ("0.10 ");
break;
default:
Serial.print ("???? ");
break;
Serial.println(" Hz");
void displayRange(void)
Serial.print ("Range: +/- ");
switch(accel.getRange())
case ADXL345_RANGE_16_G:
Serial.print ("16 ");
break;
case ADXL345_RANGE_8_G:
Serial.print ("8 ");
break;
case ADXL345_RANGE_4_G:
Serial.print ("4 ");
break;
case ADXL345_RANGE_2_G:
Serial.print ("2 ");
break;
default:
Serial.print ("?? ");
break;
Serial.println(" g");
void setup(void)
pinMode(A0,INPUT);
Serial.begin(9600);
Serial.println("Accelerometer Test"); Serial.println("");
mySerial.begin(19200);
delay(100);
mySerial.write(0xAA);
/* Initialise the sensor */
if(!accel.begin())
/* There was a problem detecting the ADXL345 ... check your connections */
Serial.println("Ooops, no ADXL345 detected ... Check your wiring!");
while(1);
/* Set the range to whatever is appropriate for your project */
accel.setRange(ADXL345_RANGE_16_G);
// displaySetRange(ADXL345_RANGE_8_G);
// displaySetRange(ADXL345_RANGE_4_G);
// displaySetRange(ADXL345_RANGE_2_G);
/* Display some basic information on this sensor */
displaySensorDetails();
/* Display additional settings (outside the scope of sensor_t) */
displayDataRate();
displayRange();
Serial.println("");
void loop(void)
old_outputValue = outputValue;
/* Get a new sensor event */
sensors_event_t event;
accel.getEvent(&event);
//outputValue = map(analogRead(A0)*multiplier, 0, 1023, -127, 127);
outputValue = map(((event.acceleration.x)*multiplier*dir), -10, 10, -127, 127);
/* Display the results (acceleration is measured in m/s^2) */
if (mySerial.available()){
Serial.print("Incomming: ");
Serial.print(mySerial.read(),BIN);
Serial.println();
if (outputValue != old_outputValue) {
Serial.print("X: ");
Serial.print(event.acceleration.x);
Serial.print(" ");
Serial.print("m/s^2 ");
Serial.println(outputValue);
if(outputValue>=0){
mySerial.write(0xE1);
mySerial.write(outputValue);
if(outputValue<0){
mySerial.write(0xE0);
mySerial.write(-(outputValue));
mySerial.write(0xB3);
delay(200);
