I have been able to run some example code and make it work with a servo but now I am trying to include this code into a larger piece so I would like to put it in an object for working with the MicroMaestro. I have a header file and an .ino file for this object but when I try to compile these files I get an no matching function for call to ‘MicroMaestro::MicroMaestro()’.
servo_obj.h
#ifndef servo_obj_h
#define servo_obj_h
#include <PololuMaestro.h>
#include <Arduino.h>
// servo class
class servo_obj {
public:
servo_obj();
void set_target(int target, unsigned long interval);
bool is_servo_moving();
private:
MicroMaestro flap_driver;
unsigned long period;
unsigned long time_now;
#endif
servo_obj.ino
Before using this example, you should go to the Serial Settings
tab in the Maestro Control Center and apply these settings:
* Serial mode: UART, fixed baud rate
* Baud rate: 9600
* CRC disabled
Be sure to click "Apply Settings" after making any changes.
#include "servo_obj.h"
/* On boards with a hardware serial port available for use, use
that port to communicate with the Maestro. For other boards,
create a SoftwareSerial object using pin 2 to receive (RX) and
pin 3 to transmit (TX). */
#ifdef SERIAL_PORT_HARDWARE_OPEN
#define maestroSerial SERIAL_PORT_HARDWARE_OPEN
#else
#include <SoftwareSerial.h>
SoftwareSerial maestroSerial(2, 3);
#endif
/* Next, create a Maestro object using the serial port.
Uncomment one of MicroMaestro or MiniMaestro below depending
on which one you have. */
MicroMaestro maestro(maestroSerial);
//MiniMaestro maestro(maestroSerial);
servo_obj::servo_obj()
// Set the serial baud rate.
maestroSerial.begin(9600);
void servo_obj::set_target(int target, unsigned long interval)
/* setTarget takes the channel number you want to control, and
the target position in units of 1/4 microseconds. A typical
RC hobby servo responds to pulses between 1 ms (4000) and 2
ms (8000). */
// Set the target of channel 0 to 1500 us, and wait 2 seconds.
maestro.setTarget(0, 6000);
delay(2000);
// Set the target of channel 0 to 1750 us, and wait 2 seconds.
maestro.setTarget(0, 7000);
delay(2000);
// Set the target of channel 0 to 1250 us, and wait 2 seconds.
maestro.setTarget(0, 5000);
delay(2000);
The error I get in Arduino IDE 2.3.2
C:\Users\HP\Documents\all_sensors_readings\servo_obj.ino: In constructor 'servo_obj::servo_obj()':
C:\Users\HP\Documents\all_sensors_readings\servo_obj.ino:32:22: error: no matching function for call to 'MicroMaestro::MicroMaestro()'
In file included from C:\Users\HP\Documents\all_sensors_readings\servo_obj.h:4:0,
from C:\Users\HP\Documents\all_sensors_readings\all_sensors_readings.ino:14:
C:\Users\HP\Documents\Arduino\libraries\PololuMaestro/PololuMaestro.h:301:5: note: candidate: MicroMaestro::MicroMaestro(Stream&, uint8_t, uint8_t, bool)
MicroMaestro(Stream &stream,
C:\Users\HP\Documents\Arduino\libraries\PololuMaestro/PololuMaestro.h:301:5: note: candidate expects 4 arguments, 0 provided
C:\Users\HP\Documents\Arduino\libraries\PololuMaestro/PololuMaestro.h:280:7: note: candidate: constexpr MicroMaestro::MicroMaestro(const MicroMaestro&)
class MicroMaestro : public Maestro
C:\Users\HP\Documents\Arduino\libraries\PololuMaestro/PololuMaestro.h:280:7: note: candidate expects 1 argument, 0 provided
C:\Users\HP\Documents\Arduino\libraries\PololuMaestro/PololuMaestro.h:280:7: note: candidate: constexpr MicroMaestro::MicroMaestro(MicroMaestro&&)
exit status 1
Compilation error: no matching function for call to 'MicroMaestro::MicroMaestro()'
